Question regarding radiator support mount
I have a 1969 Camaro and I noticed where the radiator support mounts to the subframe there are 3 holes in fore/aft position in the subframe. On the drivers side mount the radiator support is mounted in the forward most hole, but on the passenger side the radiator support is mounted in the middle hole. I can't find anything in the assy manual that says which hole these should be mounted in. Does anyone out there know??
