posi or limited slip?
Old Oct 13, 2009 | 07:07 PM
Pablo63's Avatar
Banned
From: Raised in Tilton NH now residing in Kings Mountain KY
http://www.summitracing.com/parts/ETN-19554-010/
http://www.summitracing.com/parts/ALY-12110/
http://www.summitracing.com/parts/RMG-12BC342/
Here's a shopping list for you. All you need to do now is pay for it and wait for the big brown truck. LOL Sorry spending other peoples money is a trait I picked up from my wife. < Who I love dearly if she happens to see this!
Old Oct 13, 2009 | 07:41 PM
bohuntr's Avatar
thanks....
btw...i was refering to "positive traction"...which USED to be advertised in detroit locker info..don't know if it still is...i had no idea that posi-traction was a gm thing...shows what i know(*** u me)...the offroad guys sometimes still refer to "positive traction" as "posi".....maybe we(offroad guys)are are a little "slow"!!?!!
bohuntr
Old Oct 13, 2009 | 08:49 PM
And technically, can a spool and welded spider gears really be considered two different setups? I considered welded spiders a "redneck spool".
Old Oct 13, 2009 | 09:06 PM
bohuntr's Avatar
i was gonna put that in there(i've heard that too)...but welded spider gears are weaker than a spool(i know from experience on that)...and i am from alabama...so i guess i could be considered a redneck....but im ok with that!
bohuntr
Old Oct 13, 2009 | 09:07 PM
Used the redneck spool on my first hot rod. Didn't know how to weld at that time, so I just brazed the the thing up. lol
Old Oct 13, 2009 | 09:28 PM
GRIFF's Avatar
I have a eaton posi in a 12 bolt with 4.56 gears I am fairly sure it is factory stuff. I changed the springs to a higher pressure(it has metal clutches) because when it got hot only one wheel would spin( 29 x 10 slicks) havnt had a problem since. I believe if you go to the full spool in the 12 bolt you need to cut the axle housing ends off and weld C clip eliminators on. There is a mini spool but it is only recommended for the dirt track.
Old Oct 13, 2009 | 09:31 PM
bohuntr's Avatar
i had an open amc 20 rear end in my cj7 when i bought it...welded it up with an arc welder(7018's)...lasted for 2 trips to the mountains....i guess the heat from the welding screwed up the temper in the axles...then i put a spool in it...worked fine....i finally put a high pinion reverse rotation dana 60(with a detroit soft locker)....bulletproof
im getting of the subject..sorry bout that...
bohuntr
Old Oct 13, 2009 | 09:48 PM
bohuntr's Avatar
is the eaton better than the auburn "posi"....years ago detroit also made a limited slip diff....i've had good experience with detroit stuff...none with the other brands
bohuntr
Old Oct 14, 2009 | 04:29 PM
Pablo63's Avatar
Banned
Auburns wear out more quickly, fill the rear end with powdered metal which runs through all of the bearings and gears and they cannot be rebuilt.Eatons wears a long time, put very little metal into the oil and are rebuildable. So yeah, Imo, Eatons are way better.
Old Oct 14, 2009 | 06:15 PM
  #20
bohuntr's Avatar
has anybody had experience with a detroit tru-trac?(im guessing they still make them...but dont know if they have one for a 12 bolt)
bohuntr
