por 15 use it or not ????????
As long as you not looking at building a show car is a great way to protect what you have. 20 years from now when someone scraps it off to do another restore it should look just like it does now.
used it on a 68 i did worked fine .but i first cleaned the rust with a product called chem prime or ospho available a most hardware stores.i even put it in a plastic garden sprayer and did all inner structure
It used to say on the can, that if any painted surface was going to be exposed to sunlight, it must be painted over first. Had a friend that painted a car trailer with por, then blk rustoleum, looked great after many years.
I see you took 2 pictures of your cars and made one how did you do that I would like to do the same, thanks for the help
