Pete jackson diy cam button
Hey,
First post, I'm installing a pete jackson gear drive on my 69 camaro 355, and I was wondering what does it take to install the cam button (hard, easy). I'm just needing a little direction, thanks..
if i remember right(when i put mine on)you put white grease on the front of the button and put the timing cover on,to make sure its not too close,if it is you grind it down till it fits right,this is what i did,if all else fails read the dirrections or pull them off the net...
