New Camaro Owner Need help with Spindle question
Hello,
I just purchased a 67 Camaro and it came with a bunch of extra parts. Some of which are spindles (with the dust shields)for disc breaks and rotors. The are clearly stock spindles but not knowing much about 1 gen camaros I have no clue what they are off of. I cant get ahold of the guy i bought it from to ask him. Does anyone know how I can identify what these spindles are off of?
thanks
thanks
RE: New Camaro Owner Need help with Spindle question
I jsut took some pics of them, send me your email and I will send them to you. I looked closer at them tonight and found some casting numbers on them. one of them says 371676-RH. The other one has the same number on it jsut in a different location and has a L at the end for left hand I would assume.
Thanks for your help
The cast#371676 converts to part#14012596 which is a RH knuckle for 80-81 GM F-bodies and B-bodies among other models. It is for an 11 inch rotor and probably will work if your considering converting to disc.
WindyCitySuperSport
10-31-2011 06:48 PM
