Need Help with my suspension
Old Jan 7, 2024 | 05:44 PM
NickRosa's Avatar
Default Need Help with my suspension
I'm new to this site and recently just became a camaro owner and I need some help. I recently had my suspension rebuilt on my Camaro but recently I took it out for a drive and noticed something was up with my suspension. My camber on my wheels is neutral but whenever I take it out it always ends up negative. Any help would be appreciated
Old Jan 8, 2024 | 05:36 AM
manicmechanic007's Avatar
First, shake it down for loose parts
A bad ball joint can cause what I think you are saying
If all the ball joints and tie rod ends are tight and the wheel bearings too, take it in and get it aligned
Tell the alignment man what you are fighting or not liking
The camber should be +.5 degree (adjustable with the shims on the upper A arms)
The alignment man may try to sell you "offset shafts" if the frame has caved in some and the camber cannot be corrected
Old Jan 10, 2024 | 07:18 PM
joelle king's Avatar
Did you take it to a professional analyze ?
jason8887
Jul 26, 2014 12:44 PM
Jville_hot_skate
Dec 15, 2008 03:04 PM
jb2261
Nov 23, 2008 10:56 AM
xeet2050
82-92 V8 Tech
Oct 15, 2008 10:42 PM
chvy79z
May 4, 2006 11:15 PM
