Motor Worth Selling?
Kinda hard to fog the cylinders now that the engine is pulled, unless you plan on running it on a stand. You can squirt oil in each cylinder, turn it over by hand a few times, and reinstall the spark plugs. Pull the carb, and duct tape the intake manifold shut. Cork up the exhaust manifold the same way, or cover over the exhaust ports on the head if the manifold is off. Then tape over the valve cover breather/fill hole.
