master cylinder
Old Nov 22, 2025 | 08:55 PM
R66's Avatar
R66
Did you check the push rod adjustment from the pedal to the master cylinder and if you have a booster, from the booster to the master cylinder. If it is holding the master cylinder slightly depressed, maybe the fluid is moving internally. Just a guess.
Old Nov 23, 2025 | 06:31 AM
tom Bishop's Avatar
Yeah I actually bought the tool to accurately measure and adjust pushrod. This really puzzling cause all I did was replace a sticking caliper.
Old Nov 23, 2025 | 06:44 AM
manicmechanic007's Avatar
I suspect the brake fluid all drained out of the master cylinder when you replaced the caliper
That means you need to re bleed the master cylinder first, then move on to the wheels
If you pumped it, that would send air to all 4 wheels
So, I'd start over with bleeding the system, master cylinder (again) first
Old Dec 1, 2025 | 08:44 AM
tom Bishop's Avatar
Gonna get started on it again this week-going to install new distribution valve and bleed m/c on bench while off. Then do 4 wheel bleed and hopefully that will take care of it. I'll let you know. Thanks, Tom
RoaringZ28
Apr 15, 2017 03:22 PM
ShortySMC
Sep 6, 2011 07:15 PM
brian383
Aug 4, 2010 09:57 PM
drygaudet
Apr 23, 2007 03:56 AM
ryan00s
Mar 12, 2007 11:23 PM
