Master Body hardware
Old Apr 12, 2007 | 05:26 PM
  #21
Blade's Avatar
June 2007 ROTM
Default RE: Master Body hardware
thanks brother!
Old Apr 12, 2007 | 05:31 PM
  #22
74454bb's Avatar
May 2007 ROTM
not a problem,so are you thinkin of the poly bushings?
Old Apr 12, 2007 | 05:44 PM
  #23
Blade's Avatar
June 2007 ROTM
Well I Know I need that hardware set from ricks I wanna replace every bolt on there soI have no problems.
Old Apr 12, 2007 | 05:51 PM
  #24
74454bb's Avatar
May 2007 ROTM
I would get both, it's only about 150 more,then you'll have some extra stuff for the future....Dads car when his wear. but you will see a hege differance with the polt setup, and they don't squeek, I have the black set.
Old Apr 12, 2007 | 05:55 PM
  #25
Blade's Avatar
June 2007 ROTM
hmmm, might to that I have to do something soon bc the subframe is getting close to being installed
Old Apr 12, 2007 | 06:05 PM
  #26
74454bb's Avatar
May 2007 ROTM
If you don't have the cash to do both then get the poly for now and re use the rest till later, its better to have 1/2 great parts then to have 100% 1/2 a$$ parts.
Old Apr 12, 2007 | 06:11 PM
  #27
Blade's Avatar
June 2007 ROTM
nahI would get all the parts.
Old Apr 12, 2007 | 06:14 PM
  #28
74454bb's Avatar
May 2007 ROTM
http://www.classicindustries.com/downloadcatalog02.htmWhen you get home download the whole catalog, then you can get the parts you need without getting 2 kits and save a few.....you are going to race that right?
Old Apr 12, 2007 | 06:19 PM
  #29
Blade's Avatar
June 2007 ROTM
yes the car will be raced, not all the time maybe a few times here and there.
Old Apr 12, 2007 | 06:29 PM
  #30
Blade's Avatar
June 2007 ROTM
so ur suggestion upgrade all the rubber suspension parts as well as replace all the bolts on the car?
