L72
Old Apr 25, 2018 | 09:19 AM
Douro's Avatar
Default Help identifying a part on a L72
apologies for the newbie question but I suck at auto mechanics.
can someone provide me some feedback on the hose near the oil deposit? What’s its function and should it be attached?
Old Apr 25, 2018 | 11:11 AM
kuhlman187's Avatar
You should confirm with someone else, and possibly post a couple pictures from different angles (hard to see with those shiny valve covers reflecting), but to me it looks like (don't know exact name for it) part of the pcv system. should attach to the bottom of the air cleaner housing. You can also retrofit it with an airfilter for a "cleaner" look.
google: PCV system and learn what it is and how it works. I had these same newbie questions when i got into this hobby and the hunger for more knowledge and understanding of the car and motor seems to never stop.
-Good luck!
Old Apr 25, 2018 | 11:43 AM
peterpar's Avatar
I would agree with this. You don't specify what year of car, but the attached pdf from the 69 AIM shows what I believe is the correct part identification.
File Type: pdf
Old Apr 25, 2018 | 07:37 PM
Y2K's Avatar
Y2K
The PVC is the one on the drivers side to the carb, that unhooked hose is the breather hose from the air cleaner to the crankcase to let air in as the PVC draws vapors out of the crankcase. You can replace it with a breather cap if you don't want to use an air cleaner set up with a fitting for it. Something like this but there's a bunch of different styles available that simply push in the hole. https://www.jegs.com/i/Spectre/865/4...yABEgL1OfD_BwE
Old Apr 25, 2018 | 11:49 PM
Al Loyrat's Avatar
Y2K is spot on. If you go to a push on breather, the valve cover grommet might need to be changed also. Some come with a grommet.
Old Apr 26, 2018 | 01:53 PM
Douro's Avatar
Thank you all for the help, sometimes it gets difficult to translate the correct name to English
That's definitely the breather hose from the air cleaner to the crankcase. The air cleaner base doesn't have an open insert for the hose (?). Check attachment please.
I can definitely open it and insert the hose, can this be done without creating a problem?
Old Apr 27, 2018 | 05:13 PM
fatadams's Avatar
You should be able to open the pre-cut holes in the base of the air cleaner housing. But, you will need a PVC hose fitting like this : https://www.summitracing.com/parts/spe-4960 . Just make sure that the PVC fitting base has a good seal, to protect your engine from unfiltered air.
mcsilver
Jul 2, 2017 09:12 PM
