Interior questions
I was putting in the back of my rear seat, when one of the metal tabs that hold the side of the seat back was weak and broke off. Any suggestions on how to fix the tab or an alternative way to fasen the seat down
Are you talking about the tabs that bend over to hold down the outside edge of the seat in the corner? You still have the top brackets that the the seat gets slid down into and the bolt brackets at the bottom of the seat to hold it in place.
Yes those are the tabs i am talking about. I have the seat secured at the top and the two bolts in the bottom. The passenger side tab is securing that side. It is only the driver side tab that is not. My concern with the tab being broken is that if i put it back together like it is and people ride in the back, i wasn't sure if the seat would move around
