Installing New SS Gas Cap
I went to a local car show and some nice person stole my gas cap. The cap that was on the car did not have the cable. The new cap has the cable with the nut and bolt on it. My question is how do I install the nut and bolt to the body? Do I need to drill a hole or remove a screw from the filler neck? If I remove a screw the bolt from the cap does not fit through the hole. Any advice would be greatly appreciated.
Thanks
Thanks
Of course the wire is just there to retain the cap but if you ran in the same poroblem (stolen cap) where is the point not to use the wire.
This said, it's not the wire that damage the paint but the cap itself hanging around. You can just develop an habit to use a rag between the cap and the body. I will probably do it if I decide to repaint the whole rear plate. Not sure I want to do it for just a few scratches around the gas fill neck...
You're right but this is under the cap when it is in place so not of too much a concern. AS you can see on my pictures, the neck paint is not that much damaged beyond the screw heads marks.
The cap makes visible marks on the rear panel if not cushioned.
For safety (damage and thieves) the wire could be plastic covered or replaced with a synthetic material I think.
