Inner structure
Hi All, I am putting together a 69 vert, it needs complete rocker replacement. I have the rocker assembly. Does any one here have pics and tips on replacing. The car is gutted, and I will be bracing and cross bracing soon.I have measurements from a hard top, at the door openings. I just want to use the pics as a reference.
Thanks.
Thanks.
Car needs to be assembled on a Jig. Jigs can be made or bought. This is not a job for a beginner, I am not saying you are a beginner but as a general rule someone that does not know about the assembly jig is a long way for putting a rag top back together right.
Welcome
There is a couple a build DVD out there V8 TV did a big rag top build a few years ago.
The most critical part is where the Rocker meets the cowl/fire wall. If that is not right the car will not sit right or track.
Good luck
Welcome
Good luck
I hear you on the know what you're doing thing. I am a novice at bodywork. I definitely will be enlisting the services of others. This is an area I have been before, but as a grunt. I definitely be doing a lot more research on.
