I have a totaled 68 camaro and a 67 shell can anybody tell me if I can use it in place of a 68 shell
Old 01-06-2008 | 02:26 AM
68camaroresto's Avatar
Default I have a totaled 68 camaro and a 67 shell can anybody tell me if I can use it in place of a 68 shell
I totaled my 68 camaro and have a 67 shell and am needing to know if my body lines and doors,will all work and line up before I start restoring it.I think they are basically the same shell but not sure enough to start cutting and working.ANY AND ALL FEEDBACK APPR.
Old 01-06-2008 | 07:23 AM
Default RE: I have a totaled 68 camaro and a 67 shell can anybody tell me if I can use it in place of a 68 shell
The main differents between a 67 and a 68 is the doors. The 67 had the small "Wing" or vent window and the 68 did not(see my sig). When I start looking at a project like this I will get out a sheet metal catalog and see what they break down into different part number. I checked NPD not only do they list seprate door but even the door skins have different Part numbers. Also the weather striping shows different part numbers. I would say trying to make 68 doors work on the 67 is going to a lot more then just bolting them on. Also the fenders have side markers but if you are using the wiring out of the 68 that is not an issue.
On the plus side the Repo doors can be had for $319.95 Ea. For what these cars cars are now selling for you canconcider buying the correct 67 door as a investment that will pay off.I know if I watch Craigs list I can pick up adoor that needs reskined for around $100 reposkins are about $90.
Old 01-06-2008 | 12:45 PM
Blade's Avatar
June 2007 ROTM
nice write up gorn, yea there are only a few different parts and gorn named them. All the body lines will line up correctly as long as u get a good body man. They are the same parts like gorn said 68 has front and rear fender lights and the front grill is different, with the wing glasses
Old 01-06-2008 | 01:29 PM
frostlime69's Avatar
Is'nt there an episode on "Monster Garage" with Jesse James creating something similiar?
Old 01-06-2008 | 02:08 PM
firebird69racer's Avatar
They will all fit and line up. this is what I think iswant happened to whattiten14is buying in this other thread
https://camaroforums.com/m_144611/tm.htm
and just remember if you use the 67 shell it will have to be reg. as a 67 because thats where the vin# is located
Old 01-07-2008 | 06:18 AM
MichiganMan's Avatar
January 2008 ROTM
The hinge's are different on the door's requires too much work better off getting proper door's
blacky199
01-13-2014 01:15 PM
glaxy31
07-17-2011 03:16 PM
monstercamaro
04-02-2010 09:39 AM
crimson88
07-01-2009 02:03 AM
blownv6
82-92 V8 Tech
07-15-2007 09:39 AM
