How do i make my 68 a z28?
RE: How do i make my 68 a z28?
Bro, there is alot to do to clone it. I recomend buying a book about the history and/or the identification of 1st gen Camaro's. If you would rather use us a your resource you will be here a long time. Its more than what is simply in the white book. Obviously the 302 would be the first thing. Then the suspention stuff. If its all exterior then you will have an easier time but, to truly make it as numbers matching as possible will take time.
Well, there are about 30,000 or so people out there that probably can help you. Here's about how it goes:
Forget the motor, because that's expensive. All you need is a glovebox decal for the correct tire inflation information, a couple of bucks for some emblems, a 4-speed conversion, and some four-piston front brakes and the correct rotors. Everything else that is then missing you can make up a B.S. story about as to where it went over the years... Just say you bought it from a friend's uncle, and the engine, radiator, transmission, and rear end were all blown up street racing.
Embellishing this street racing legend helps as well; make up a story about "yeah, this z/28 used to run like a big block, yada-yada..." You'll begood to go!
ORIGINAL: Iron_Balls_McGinty
Bad idea my ****...
Every Camullet out there at this point is suspect. Let's face it-- How many base motor, non-SS, RS,or Z/28 cars do you see when you go anywhere? Based on this, the guy is doing himself a disservice by NOT cloning the Z, especially if he has a '68.
Bad idea my ****...
Bad idea my ****...
Excellent point Willie!
There are two ways to clone, if you are set on doing it. One is to badge the car and make a Camaro that looks like the original (tribute car). Or, actually duplicate the original with every part and then try to pass it off as original. The first shows taste. The second is downright criminal. If you want a Z car, buy one, if you want a plain Camaro buy that.
