Horn and Radio Not Working
Old Jan 19, 2008 | 11:01 AM
jkkrs310's Avatar
Default Horn and Radio Not Working
Can anyone help with possible sugeestions for a horn and radio not operating. I have a 1969 SS/RS 396.
As for the radio (original AM radio)I verifiedthat the unit is getting power but nothing happening with I turn it on not even static. I still need to check speaker but I'm guessing that the speaker is ok. If unit is bad what do you guys recommend..........1) try and find replacement or repair?
For the horn I have the original wood steering wheel. I took it apart and it appears that all ofthe parts are there. I believe the horn works bypushing thehorn **** which grounds the system??? If so there should be powercoming up through the steering assembly for the horn to ground out, right?? Horns are ok so I was going to check relay......could the relaybe bad? If so how do you check.
I appreciate any input. Thank you in advance.
Old Jan 19, 2008 | 08:21 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: Horn and Radio Not Working
Radio: If its the speaker, I would replace it (them). check continuity of all the wires first.
horn: same as above.These are old cars and unless you know the wires to be new, I would go through the entire system and replace as needed.
PCweber
Apr 27, 2012 12:55 PM
Nite
Sep 13, 2009 07:07 PM
monolithmonolith
Jun 27, 2008 11:26 PM
91camarodave
82-92 V8 Tech
Dec 20, 2007 09:48 PM
