Holley EFI Sniper Setup
Does anyone have experience with installing a Holley Sniper EFI on their Camaro? I知 going to need their fuel tank kit and I知 wondering if I need just the efi unit or do I need that kit too. Also any words of wisdom in doing this install would be appreciated.
Thanks
Gene
Thanks
Gene
You will need a high pressure, EFI pump, a standard fuel pump, whether it be an electric or mechanical type won't cut it, if that's what you're asking.
I don't have any experience using one of these kits, but my friend purchased one and said at one time, Holley had two kits, and the later kit was a lot easier to wire.
Not sure what he meant, but I'm sure Holley must have made a revision at a later date and that seemed to be the kit most people wanted.
Again, this was last year so I'm sure it's all worked out by now.
I put the Sniper on my 69 Camaro 406 small block.
I was very happy that they also sold the fuel sensor and fuel pump that fir right in my tank.
No need for a return line. No need for the high dollar tank or external noisy pump.
I am very happy with the set up.
Hope that helps
Hope that helps
Jr. Mechanic
Mar 9, 2010 10:46 PM
