Holley EFI install hours
Old Dec 11, 2021 | 04:59 PM
Iqbal Shoker's Avatar
Default Holley EFI install hours
HI all. I知 being quoted 25 hours to install a Holley efi and fuel return on my 69 camaro. Does this sound about right? I知 reading the fuel return take some time. The unit is about $1900 Canadian and about the same for install. Ads up
Old Dec 13, 2021 | 11:30 AM
Turbo86's Avatar
Seems high, but not clear on what needs to be done. If you converting over to a complete EFI system from a carbureted, then yes. Lots involved if your upgrading other than just changing out the intake system. Have to think about fuel lines, custom linkages, vacuum system, fuel pump, wiring.... Same if your just swapping out the carb, but get a list of changes and you might get a better understanding of the scope of work and the time it takes.
Old Dec 13, 2021 | 11:56 AM
This is not normal work you can look up a time for, Every shop is going to quote at different hours and how the install is done will effect the price. I watch the guys from Road Kill install a kit in 2-3 hours in the parking lot. (installed or temporarily slapped in you pick the words) Even something how the fuel lines are run can make a huge difference on how long the job takes. You will find shops out there that would rather not do this type of work but like to say they can do anything. So they just over quote the job so you will take it someplace else, You want to start at hotrod shops cause this should be their bread and butter.
Old Dec 13, 2021 | 12:11 PM
Thanks man. Make sense. yes its a full overhaul job
Old Dec 13, 2021 | 12:13 PM
Hot Rod shop never thought of that. Appreciate that
jerhofer
Mar 28, 2011 09:53 PM
par6439
Mar 6, 2011 11:52 AM
1Quick427
Jul 23, 2010 10:56 AM
buckmaster
Oct 2, 2009 03:44 PM
hotcornernoprob
LS Series Tech
Nov 4, 2006 03:24 PM
