holley carb...
I have a holley street avenger 680 and its been nothing but problems. I have been through it twice. The carb will not hold a consistent idle. When you drive it wants to stall out. Does anybody have this carb and if so have you had these problems. Is there any fix for this
i have a holley on a 355 small block in a 55 chevy and i too have had nothing but problems. ive blown out powervales and the thing wont keep running. also family has had nothing but problems with holleys so i would recomend throwing said carb into trash. i fixed the 55's problem by swithin to tri power
ps im really bias on feelings for holley so dont take what i say to heart. im extreamly po'ed because i cant get the thing to run either.
I agree completely, throw the Holley in the trash. But instead, for feel-good ecology reasons, I'll send you my address to where you can send the carb, and I'll "dispose" of it properly.
![Wink](https://camaroforums.com/forum/images/smilies/wink.gif)
What is your fuel pressure?
What is your manifold vacuum at idle in PARK?
Which # power valve?
What primary Jets are you running?
What secondary Jets are you running?
What is the squirter number?
Did you loose the check ball under the squirter?
Did you use the correct gasket for the base plate? The trick kit gives you several that will "fit", but you have to use the one for your specific carb. The rest you throw away. (Unless you have another carb your saving them for).
How do you know you used the correct gasket?
This should get us moving in the right direction.
If you want a quicker answer, call the guys at Holley. http://holley.com
Hey Camaroboy,
I can certainly understand your frustration. You weren't alone prior to 1992 when a backfire through the carb could take out your power valve. Since 1992, that's just not the case anymore.
http://www.holley.com/data/TechServi...wer_valves.pdf
When I first started my engine, I blew a flame about 2 foot tall and had several smaller burps before I got my timing dialed in a bit closer and it didn't hurt the carb one bit.
Growing up poor, I've had plenty of Rochesters because that's what most cars came from the factory with, and I actually got pretty good at tuning them. Then we went to Carter, so when I finally got a Holley, I was kind of afraid of them. Not anymore... I simply cannot believe how simple they are.
Hey, tri power is way cooler than a single carb anyway!
