Help with mounting brake booster
Old Sep 19, 2019 | 08:58 AM
Mike68396's Avatar
Default Help with mounting brake booster
Hello All
I am in the process of converting to front power disc brakes. Fairly easy process took about three hours to do. One question I have. Does anyone know any tricks for getting the bottom two nuts on the brake booster? I got the top ones on with a lot of patience but I can't seem to figure out a way to get to the bottom.
Thanks
Mike
Old Sep 19, 2019 | 11:49 AM
Warthog639's Avatar
Mike, Did you tighten up the top nuts? Not sure how much room you have, but you may have to back off the top nuts so only one thread is holding the booster on and slide the booster forward so you can get the bottom 2 started.
Larry D
Old Sep 19, 2019 | 07:26 PM
Mike68396's Avatar
Thank you for the reply Larry I did try to just slightly tighten the top 2 but it makes no difference as I cannot even reach the bottom 2/
Old Sep 20, 2019 | 06:04 PM
flat tire's Avatar
you may have to remove the fender. I installed mine with the front clip off
mark every bolt/washer location with a pencil before loosening them . tape all shims together and mark they where they go
Old Sep 21, 2019 | 09:12 PM
Mike68396's Avatar
Thanks for the replies I finally got them on took a lot of twisting and turning without being able to see anything but they are on.
exlimey
Feb 1, 2012 04:23 AM
typeomang
Jun 14, 2011 02:00 AM
Foxracing254
May 19, 2010 03:30 PM
423hycar
Jan 27, 2010 04:57 PM
zman3689
Mar 31, 2009 08:48 PM
