help
Old Aug 14, 2011 | 10:04 AM
gaslineswelder's Avatar
Default help
i'm having a hard time with my power steering. i have a 1977 block in my 1969 camaro and the power steering pulley won't line up. what can i do?
Old Aug 14, 2011 | 10:23 AM
well first you need to be in the right section. i can help you there,,, moved to 1st gen section for ya.
Old Aug 15, 2011 | 10:37 AM
StoveBolts's Avatar
I can't see the difference in the year of the block making a lot of difference. However, I seem to recall something about water pumps... Like maybe one has a longer nose than the other which can be causing some of your issues.
I wish I could be more accurate, but maybe go to a parts store and ask to see a water pump from a 77 and one from a 68. This may be as easy as just changing out the pump.
And then again, I could be totally wrong... Something to look at though. Let us know either way would ya?
Old Aug 15, 2011 | 03:22 PM
Chevy changed over to the long water pump for the 69 models, in most everything except the Vette. For mounting, the 77 engine wouldn't be any different from the 69, but the p.s. pump, pulley, or bracket could be. Are you using the pump from your 69, or was there one on the engine that you're using instead?
Old Aug 15, 2011 | 03:47 PM
1969 SS's Avatar
I'm assuming it's a small block from '77? what is it not lining up with? everything else lines up perfect (alternator, waterpump, A/C if you have it)?
which type of p.s. pump do you have on there and what type of waterpump? are you using original type brackets or aluminum aftermarket?
You need to give more details than what you have given. Very vague questions can only get just as vague answers
