Headlight Question
Headlight Question
New Grill
I just installed a new grill in my car, and if you look at the right side (passenger) headlight, you can see it appears to not fit in the trim ring properly.
The driver side fits in nicely.
Any thoughts on what might be the issue?
The bucket is in tight, the headlight bulb is seated properly, the only thing that is off, the stainless steel ring that holds the headlight looks to be out of shape a little
but it's holding the bulb in tight.
Thanks
