Headers
Old 01-23-2016, 11:53 AM
Milan's Avatar
Default Headers
67 Camaro 383, Promax Heads. I'm having a hard time finding headers that will fit the promax heads. The issue is the plug wire boots are hitting the headers and the power steering box is in the way. (straight plugs) Is anybody using the Promax heads and what headers are you using?
Thanks
Old 02-04-2016, 09:06 PM
Did you find a set of headers.
Old 02-04-2016, 09:10 PM
Default 1969 camaro headers
I am looking for a set of headers for 1969 Camaro with angle plugs.
Old 02-04-2016, 09:46 PM
Milan's Avatar
No not yet. Not knowing what will work I cant just start buying headers just to see if it will fit. I may just dimple mine to make it work.
Old 02-05-2016, 05:17 AM
flat tire's Avatar
fwiw I have pro comp angle raised port heads and I used hooker super comp.
I had to dimple 1 tube for the idler arm and 1 for the pitman arm, but I have a small block sitting on big block frame mounts and the BB trans cross member
Old 02-05-2016, 08:00 AM
Milan's Avatar
Thats good info.
Thank You
ricer_killaZ28
05-31-2010 12:37 PM
2fast4u
06-04-2007 08:34 PM
meangreen98
10-22-2005 06:41 AM
xxbassheadsxx
07-05-2005 04:40 PM
whiteZ28
04-28-2005 05:51 AM
Quick Reply: Headers
