Headers
67 Camaro 383, Promax Heads. I'm having a hard time finding headers that will fit the promax heads. The issue is the plug wire boots are hitting the headers and the power steering box is in the way. (straight plugs) Is anybody using the Promax heads and what headers are you using?
Thanks |
Did you find a set of headers.
1969 camaro headers
I am looking for a set of headers for 1969 Camaro with angle plugs.
No not yet. Not knowing what will work I cant just start buying headers just to see if it will fit. I may just dimple mine to make it work.
fwiw I have pro comp angle raised port heads and I used hooker super comp.
I had to dimple 1 tube for the idler arm and 1 for the pitman arm, but I have a small block sitting on big block frame mounts and the BB trans cross member |
Thats good info.
Thank You |
