GRRR Damn Wiper
I bought a new wiper motor. i connected it and it ran once then stopped, I took the motor out and turned it by hand, when i did that i notices that the motor has to land in a specific place for it to continue working. if i nudge it with power and gets out of its sweet spot then it stops working.
so i aligned it to were it works, then pluged it directly to a 12 volt and it worked. The problem is that every time i put it back into the car, it turns once then does not work again unless i take it out and manually put it back to one of the positions it likes. Then i put it back, and same thing turns once and thats it.
What am i doing wrong???
Thanks
Rick
67 Camaro
Thanks
Rick
67 Camaro
