Good or Bad??
Old May 2, 2011 | 04:00 AM
wantvegas's Avatar
Unhappy Good or Bad??
So i just found out my Camaro that I thought had a 350 in it, only has a 327. But the 327 is matching numbers with the car. So, should i be sad about it not having a 350? What is the difference between the 2? Thanks!
Old May 2, 2011 | 04:04 AM
BasicConcepts's Avatar
Technical User
i looked at a 79 once that had a 327... asked around and massey said hed rather have a 327 than a 350 (cant quite remember why) but massey, craby, and cam69 are imo 3 of the smartest guys on the forum (when it comes to camaros) if i have a serious problem or want a really good answer i ask them
Old May 2, 2011 | 08:12 AM
You have a matching numbers engine, which is a great thing to have for higher car value. The one obvious difference is a 350 has 23 c.i. more. But the 327 has a shorter stroke, so it can wind the rpm's higher than a 350. Yours was a 210 h.p. model, with a 2 barrel. But from your other post, some things have been changed/upgraded. The 327 is no slouch, or at least has the potential to not be one. Back in the 60's, 327 Vette engines were putting out 350 h.p. with hydraulic lifters, and 365 with solid. Be very happy with the engine you're "stuck" with, I would be. You can always do more to it if you want in the future.
Old May 2, 2011 | 01:36 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
i would be jumping for joy. i love the 327 chevy. i have one in my 68 thats to the specs of the 350 horse and that car aint no slouch. it revs quick and has quite a bit of power than what you would think.
Old May 2, 2011 | 05:14 PM
wantvegas's Avatar
Talking
Great! Thank you! I am glad now! It does have a 4bbl, camel hump heads, hooker headers and some other lil goodies, so i am sure i am above the 210 HP! Thank you everyone!!
Old May 4, 2011 | 11:13 AM
maggie67rs's Avatar
stroked out a 350 after cracking the matching 396. about 200lbs lighter and a lot more powerful but yearning for more. would need serious subframe mods etc, so for now i'm content.
Old May 4, 2011 | 03:42 PM
dj69z28's Avatar
The 327 is one of Chevy's greatest motors bro! The DZ302 was made from a 327 block as well. 350's were great too, but the 327 was a classic high revving motor that ran great and rarely had problems. And like "69 Camaro" said, numbers matching is a VERY good thing when it comes to value! Keep that motor and enjoy.
Old May 17, 2011 | 06:34 PM
tabascoboy's Avatar
Most these vintage 327's were 2 bolt main, small journal engines, so if you try to get too much out of them they will break. But....if you stick to the basic street hot rodding upgrades it will serve you well and as was stated they really rev! Even if you do another engine at some point, having the original engine is never a bad thing so hang on to it.
Tabascoboy
Old May 18, 2011 | 06:10 AM
maggie67rs's Avatar
my pal beats down a stroker eng in his 67 vett w/no worries while storing the matching eng to preserve it. an expensive option but less than the depreciation of a car w/ a ruined original.
Old May 18, 2011 | 04:10 PM
burnt68's Avatar
December 2010 ROTM
ALL 327`s are 2 bolt mains, i have one in my 68 vette and they are as fun and as fast as most 350`s!! put one in front of a 4 speed and even more fun, i run mine up to 6500 rpm alot!!
