Gas Gauge Goes Way Bellow Empty
Old Aug 28, 2023 | 10:56 AM
Raticalrich's Avatar
Default Gas Gauge Goes Way Bellow Empty
I replaced my right side fuel gauge in my 69 with a tach and installed an aftermarket center fuel gauge. Old, original gauge works fine. The new center gauge works fine with key is on but when I turn key off center gauge goes way bellow empty (8 o:clock if it was a clock), original gauge does not do that. Thought it was a bad gauge so I got another new center gauge and it does the same thing. Rechecked original gauge and works fine still. Pulled sending unit and checked and it checks out. The place I purchased the gauge from says the gauge should not do this. I believe it is a problem with the gauge design and the selling company is wrong, I can't believe GM gauges had this situation going way under "E"
Anyone out there seen this issue? Any cures?
Raticalrich
Aug 25, 2023 02:25 PM
mwightman
Feb 27, 2019 03:18 AM
Twohats
Oct 25, 2016 08:09 PM
Demonskin
Dec 21, 2013 05:08 PM
Crutjd
Feb 6, 2012 06:01 PM
