garage heat ?????????
Old Oct 28, 2012 | 08:25 PM
mikes68's Avatar
Default garage heat ?????????
just got done installing a big maxx gas heater in my new 24x24 garage ,but not sure if i want to leave it on all the time set at like 45 or just when am in there i think going up and down with the temp would cost more to run , guess i have a fear of it starting the garage on fire what do you guys set your garages at
Old Oct 28, 2012 | 08:53 PM
BasicConcepts's Avatar
Technical User
When I lived in NY my buddy had a pretty big shop (you could fit 2 semi trucks in it and still have some room) he was running a gas heater at 50°. After about 3 months he never turned it on again (too expensive) and installed a wood burning stove. Kept the shop at about 70° for pennies.
Old Oct 28, 2012 | 09:16 PM
Scooch's Avatar
Super Scooch
January 2009 ROTM
yea, I use to work in a 20,000 sq ft shop. the owner put in nice gas heaters throughout. it was so expensive to run them that he shut them down in a month and brought in Barrel Heaters (thats what I call them). Basically two 55 gallon drums, sideways... one of top of the other. They put out TONS of heat for dirt cheap. so, If you already bought it and hooked it up, then Id say go ahead and use it but only when you are out there. maybe go out and turn it on an hour ahead of time or something to get it warmed up.
Old Oct 29, 2012 | 02:53 AM
slick's camaro's Avatar
Set your grill in the garage and turn it on.
Old Oct 29, 2012 | 06:29 AM
Camambro's Avatar
April 2012 ROTM
My garage is gas heated on low like maybe 50 but mine isn't huge
Old Oct 29, 2012 | 10:02 AM
I never heat my garage unless I'm in there working. We rarely get much below freezing in the winter, so it's not needed to keep the car warm.
Devin's camaro
Jan 2, 2011 01:42 PM
burning camaro
Nov 9, 2010 06:15 PM
