front springs
changed my front springs today in my 68 camaro and it sits 3 in above the front wheel
ordered springs for a 69 because mine has disc so i know that did not come with disc brakes but the 69 did. what went wrong are the springs to big help |
RE: front springs
Looking atthe application guide at Classic Industries, the 68 and 69 usedifferent springs in some instances, and some are the same, depending on the options. That's a big difference you have though, are you sure they didn't send you big block springs?
RE: front springs
fixed the 68 camaro today, took the new springs and cut a 1/2 coil instead of 1 coil and the carhas a good stance, nowthe tiresabout 1 3/4to 2 in from the front fender.
also replaced upper control arm bushings and the toe is correct, very happy:D |
