Front Bumper Driving Lights
Old Dec 27, 2009 | 09:14 PM
1969_RS's Avatar
Default Front Bumper Driving Lights
Hi All,
Quick question... I recently purchased a '69 RS, and discovered that the driving lights on the lower front bumper were not connected to anything... Where should they be connected? Do they turn on with the head lights? or just the running lights?
Thanks!
Old Dec 27, 2009 | 09:42 PM
Originally Posted by 1969_RS
Hi All,
Thanks!
If you have driving lights mounted on the front bumper, then those were aftermarket added on, they aren't factory lights. They would have been wired with a toggle switch somewhere by a previous owner.
Old Dec 27, 2009 | 10:46 PM
skidoodave's Avatar
Are you talking about the park/turn signals in the lower valance below the bumper. By looking at the pic in your sig, I don't see any driving lights. If so, then look around the headlight harnes for loose wires tucked away or taped up.
Old Dec 28, 2009 | 09:40 AM
1969_RS's Avatar
Yes, I am talking about the lights below the bumper. I do not have any added on extra or after market lights. So, they are supposed to turn on when the headlights are turned on then? also blink with the turn signals?
Old Dec 28, 2009 | 10:38 AM
Yes, those are your front running lights and turn signals. They should turn on with both positions of the headlight switch. There should be a wiring pigtail on the back of the light housings, with a plug on the end. The wires pass through the flat area of the inner fender on the engine side of the radiator core support, and plug into the main wiring harness near that point.
Old Dec 28, 2009 | 11:28 AM
1969_RS's Avatar
Thanks! I will take a look.
Old Dec 28, 2009 | 04:36 PM
mcmcmahon's Avatar
Make sure you put some yellow bulbs in there.
Old Dec 29, 2009 | 06:11 PM
dj69z28's Avatar
Mcmcmahon is right. Those should be clear lenses with amber bulbs. 1157 bulbs act as your running lights and turn signals. Got to have those to drive! Good luck!
Old Dec 29, 2009 | 11:20 PM
skidoodave's Avatar
Not being a smart a** but they are actually 1157A bulbs. "A" for amber, just incase you didn't know.
Old Dec 30, 2009 | 02:06 PM
lostcybersled's Avatar
Thanks for the clarity Dave lol
