Frame Connectors for a '69
Old Feb 2, 2022 | 08:57 AM
markblack1971's Avatar
Default Frame Connectors for a '69
I want to install weld in frame connectors on my '69. I want ones that will tuck up as high as possible and i do not want to cut my floor at all. Can someone recommend good connectors for me?
Thank you!
Old Feb 3, 2022 | 06:42 PM
1st Gen's Avatar
Default Sub-frame Connectors
We used 'Detroit Speed' sub-frame connectors on my '68, but cut the floor pan and counted that as a plus, as the connectors not only weld to the rear sub-frame at the spring perches, and at the front sub-frame via fish-plate welds once it rejoins the body, but also is seam-welded for a long strip on each side of the floor pan, both top and bottom, further ensuring that the right side of the body doesn't want to move forward at a different rate than the left side. The only minus I could see to this installation was an uneven floor for rear seat passengers. In the five or six years I actively drove this car on a daily basis, I never once had a rear-seat passenger, and probably won't moving forward.
Since you're willing to weld to both sub-frames, it seems probable that you have no attachment to retaining a pristine dealer-showroom Camaro, so I'm curious to know why you don't want to cut the floor pan. Concern about transmitting frame vibration to the body?
The geometry of a strong connector seems to dictate a need to cut the floor, to maintain a straight line between rear spring perch and front sub-frame end. However, Detroit Speed's connector is the only weld-on unit I'm familiar with. By the way, you can view the install on my diary in the 1st Gen Projects forum, titled "Ricky Camaro Rebirth", at entry 25, dated 11-22-2021. There are pictures there of the install before any coatings were applied. with views both in and under the shell.
Old Feb 8, 2022 | 11:15 AM
bruce69camaro's Avatar
Have you given a thought to buying bolt in and welding those in?
Check out this page from Classic Industries on some connectors.
https://www.classicindustries.com/sh...me-connectors/
The ones by BMR are interesting, and Global makes some nice ones.
I used S&W Racecars frame connectors on my car, but for something like what you want, a bolt in may be better and then just weld it in place.
Old Feb 11, 2022 | 05:02 PM
SoCal67's Avatar
Summit brand bolt in's then just weld them. $120 IIRC
Old Feb 12, 2022 | 06:54 AM
Everett#2390's Avatar
Or a set of Heidt's
Jacouncil3
Mar 22, 2025 09:25 PM
Baron69
Nov 13, 2021 06:30 AM
blee62
Oct 6, 2010 04:54 AM
mcmcmahon
Nov 22, 2009 08:55 AM
coprunr
Dec 18, 2007 06:33 PM
