Flickering lights 69 z28
All of the lights flicker when the engine is running. I cleaned the ground wire from the battery, but it didn't help. Any suggestions? We think it might just be a bad alternator.
When the engine is running faster, the lights flicker faster and it is less noticeable.
![Name: Camaro3.jpg
Size: 18.2 KB](https://camaroforums.com/forum/attachments/67-69-general-43/41691d1501340427-flickering-lights-69-z28-camaro3.jpg)
also, how can i put a picture in my signature?
![Name: Camaro3.jpg
Providing you have an original style alternator, you'll have a separate voltage regulator that's located on the radiator core support, drivers side. A bad regulator will make alternator output erratic like what you're experiencing. Output at the alternator should be in the 14v range.
Decent looking car.
Decent looking car.
ORIGINAL: scott14oh
[imag]http://i110.photobucket.com/albums/n88/scott14oh/Camaro3.jpg[/imag]
Change the word "imag" to "image" at the front and back of the code. If I put it that way, your picture would show instead of the code.
You'll need to downsize your picture too, it's a bit big now.
since it's all original, a common problem is that a lot of the time,the connector going into the regulator doesn't have a good connection. a lot of people just use a ziptie as insurance.
