First post turn signal issue
Old 05-31-2014, 12:31 PM
msp1055's Avatar
Default First post turn signal issue
I need help. I have 67 and the left turn signal indicator was not working. I figured it would be easier to just pull the bezel out and change all of the bulbs. I discovered that the generator plug was in the right turn signal, not the 194 bulb as required. So I switched all the bulbs out for new, along with the external tail light bulbs. Put back together and issue: Activating the turn signal in either direction makes all four flash, turning on the headlights stops the flashing and with the headlights off, if I depress the brake pedal the right side, fuel gauge pod turns on the back lighting.
Sorry for the first post being a problem, but hopefully someone can help.
Old 05-31-2014, 07:22 PM
Sounds like you may have a poor ground attachment under the dash, causing electrical feedback gremlins.
Old 06-01-2014, 08:11 PM
msp1055's Avatar
Sounds about right. I've got turn signals now on both sides, however with the right turn signal flashing, my right fuel gauge back lighting and the back lighting to the heater control flashes.
dsours69RS
67-69 I6 Tech
08-18-2021 11:31 PM
sdotbailey
03-05-2014 09:56 AM
fastbenni78
08-28-2013 05:04 PM
nnewquist
02-18-2012 09:55 PM
wolfy692005
08-14-2011 11:20 PM
Quick Reply: First post turn signal issue
