Finally found the right one.. Suspension Recomendations
Hey guys,
Been looking for the right '68 for about a year. This one landed in my lap. First order of business is suspension, brakes and steering.
I'm getting bogged down researching the suspension kits. They range from $1,000 to $6,000 or more. Won't be drag racing, just cruising, getting on it every now and then. Has anyone done a coil overs on all 4 corners plus all the other goodies? I have no problem spending the money if there is a payoff, but obviously don't want to buy what I don't need. What will make the biggest difference in drivability? Also, solutions for tightening up the steering?
Here are some pics of the new ride. Thanks...
A 1 1/8" sway bar and sub-frame connectors will help. Several brands to chose from. I just got Summit brand.
If you want to lower the car I would, and did, the RideTech lowering progressive springs (1 5/8" drop) and lowering blocks (1 1/2"-2") in the rear. Speedway and most part suppliers have them
There are better steering boxes. One from a Jeep, not sure of what years. It will require different hose fittings and a rag joint but otherwise a bolt in. LEE makes a very nice tighter ratio unit but it is around $680 IIRC
Google David Pozzi if you want a more aggressive system as he is very knowledgeable on the 1st gens suspension upgrades
69bigblockpower
10-31-2010 05:23 PM
