Factory tach install help
Old Apr 17, 2008 | 01:11 AM
FATHOM GREEN 1969's Avatar
Default Factory tach install help
I just pulled the factory fuel gauge out and need to install new factory tach in its place.
Tach is much deeper than fuel gauge?? Do i need to cut the cack of the area where original fuel gauge
was? Does factory tach split into two pieces?
Baffled.
Please Advise.
Thanks, Eric
Old Apr 17, 2008 | 07:33 AM
scottlee1's Avatar
Default RE: Factory tach install help
did same conversion, take a dremel and cut out the back of plastic dash cluster. the tach will fit fine. it seems like you have to be careful to leave enough material to attach tach to. run the tach wire to coil and ur rolling
scott
Old Apr 17, 2008 | 10:08 AM
dacats67's Avatar
post some pics of your car when you can in the new members section, come out to the Show and Go car show first weekend in May in riverside ,nothing like cruising the downtown area
Old Apr 17, 2008 | 01:15 PM
Thank You for advice re factory tach install.
Tach will get installled later today.
Old Apr 17, 2008 | 02:41 PM
5speed502's Avatar
Actually did the same just recently. My guage cluster is a reproduction, but there were lines marked on the reverse side showing where to cut. Look closely, yours may have them as well. I just used a small coping saw with a very fine blade, and it worked perfectly.
Looks great installed too.
J.
jrgearhead
Sep 18, 2011 10:28 PM
socalrs
May 15, 2011 12:50 PM
blue_thunder01
LS Series Tech
May 23, 2010 04:52 PM
evilzee28
67-69 V8 Tech
May 10, 2009 03:36 AM
