deluxe int. door opener?
the 68 I am working on has the deluxe int.I ordered door opener rods ,they dont seem to be correct.everyone seems to carry the same part. my guestion is are these rods the same for deluxe handles that pull out instead of up.
I don't think thu are since the pull is also in a different location compared to the std hadle. It's been so long since I've had my door panel off on mine. The end where it meets the handle would be different because you pulling out not up
you guys Pull handles are in different locations depending on standard or deluxe? I was gonna say all I had to change was the pull mechanism itself, I was able to attach the basic factory rod.
Yeah I think so I can't remember now when we had those two 67's with std interiors. I think 68s deluxe pulls are in a different location the more I think about it.
thanks guys.the pull rods that I have look to be long enough .the problem is the angle of the ends in relation to the holes in the mechanism on each end.I may try to heat and twist what I have if I cant find the corect ones.
