Casting number help
Old Sep 11, 2007 | 08:47 PM
sweetquads's Avatar
Default Casting number help
Is there anyway to tell axactly what an engine block came in? I have looked up the engine casting number on this block and as far as i can tel it could be a 327, 350, came in a truck, car or vette? Any way to narrow it down?
Here is the castingnumber:
3956618
Old Sep 11, 2007 | 08:56 PM
buckmaster's Avatar
Default RE: Casting number help
You need the stamps (not castings) off the block from behind the alternator. 2 sets, one gives the plant, production date and horsepower, the other gives the application and vin number suffix
Old Sep 11, 2007 | 09:06 PM
sweetquads's Avatar
I looked that number up as well and it didnt really tell me anything either. a few applications it could be but nothing specific. Also there was no VIN stamping, just the suffix.
One more question, the heads, i got the number from them. It is 3947041, i looked that number up at this wensite:
http://www.donsautopages.co.nz/chevheadnumbers.htm, but it shows that number twice, i cant figure out what it means. Any help there too would be appriciated.
Tom
Old Sep 11, 2007 | 09:32 PM
sweetquads's Avatar
The suffix code is either:
10113HB or
TOI13HB or
TOII3HB i cant really tell for sure.
Old Sep 12, 2007 | 09:19 AM
Ircyklops's Avatar
these links should help...
http://www.camaros.org/drivetrain.shtml
http://www.chevy-camaro.com/chevy-ca...es.asp?group=4
3956618 = 1969 block
That would be T0113HB....
T = T for Tonawanda (NY) Engine Plant;
01 = January;
13 = 13th day;
HB =
HB- 1967 327 275 4 A.I.R.
HB-1968 327 275 4 H.D.clutch
HB- 1965 327 300 4 std trans., hi perf.
HB- 1966 327 275 4 A.I.R.
HB- 1969 350 300 4 turbo hydro trans
It appears that you have a 1969 350/300hp 4bbl with an automatic trans.
see how easy it is...
Old Sep 21, 2007 | 07:18 PM
buckmaster's Avatar
You should try to check the vin stamp now. If you locate the othere stamp it will read something like 19N123456. That indicates 1- chevrolet, 9- 1969, N- assembly plant Norwood, then the 6 digits are the vin of the original vehicle. If that matches the last 6 of your vin, you have the original motor. And, it appears from the info you provided, you would have an SS. Keep us posted.
Old Sep 21, 2007 | 07:32 PM
sweetquads's Avatar
ORIGINAL: buckmaster
What makes you think its an SS? I know its not the origional motor. My car is a 68
Old Sep 21, 2007 | 09:22 PM
buckmaster's Avatar
My belief is that a 350 300 hp motor was only available as an SS car. Could be wrong though. What is the vin suffix?
Old Sep 22, 2007 | 02:26 PM
wildpaws's Avatar
You are correct, Camaro '69 350 300hp was only available in SS, though there were other engines available in the SS, the 350/300 was the base SS engine.
Clyde
Old Sep 22, 2007 | 05:39 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Is the block bare? I mean can you measure the bore and stroke? That would help ID the block.
CaseyW
Jan 5, 2015 05:38 AM
bear9820
82-92 V8 Tech
May 8, 2011 07:36 PM
sewerrat
Jul 20, 2008 10:27 PM
Bluedevils39
Jul 20, 2007 03:00 PM
cplthomas
82-92 V8 Tech
Jan 28, 2007 05:45 PM
