camaro paint
RE: camaro paint
Depending on your trim tag info - try http://www.digitaldorks.com/jim/68info.aspor http://www.68rscamaro.com/camfacts/
RE: camaro paint
I wouldnt have a clue as to what advice to give you. I went with my fav color and knew exactly what color scheme I wanted for inside the engine bay. So is your first name Holly or is that just your screen name???
RE: camaro paint
You should have a trim tag on the firewall. It will have the paint code on right side,2nd or 3rd line.Should be letters like R R = red lower red top.If you have a vinyl top or convertible, 2nd letter will be different.Tell your paint supplier the code , they can look it up.
I have another question for anybody that can help.on paint. What is the dash supposed to be?Gloss,semi-gloss?Mine is black,I don't think it is gloss.What should it be?Thanks,Ed
RE: camaro paint
I went to Ebay and bought an original copy of the 1969 Camaro Sales Brochure, it has a photo of the car with every original paint scheme that was available, colors and all. I just went and checked, they also have them for the 68 as well, you should look into it. Good Luck.
RE: camaro paint
If original is your goal, then go for it!
But, if you are not planning a nut & bolt all original, the paint will not make much of a difference in the value of the car. Rare models are certainly worthy of such restorations.
Pick a color that you like and run with it. You can always paint on the stripes to give a somewhat factory appearance.
