Brake pedal assembly
Old 05-06-2014 | 10:49 AM
rchate1's Avatar
Default Brake pedal assembly
Hi, I have a 1967 Camaro,I am changing from standard transmission to automatic, and I want to change the clutch/brake assembly to a brake only assembly, I am having a hard time finding one. Are there other car brake assembly that will fit my car?
Thanks,
Old 05-06-2014 | 12:30 PM
All I did with mine was remove the spring from the clutch pedal arm and drop it to the floor, and use the existing brake pedal as is. Or you could leave the clutch pedal up so that your buddies will think that you're still a "cool dude". And/or use the clutch pedal to function as your neutral safety switch mechanism.
Gen1admirer
02-17-2013 12:36 AM
tattoo400
07-15-2012 02:52 PM
69SS427
04-15-2011 09:10 PM
jasunf
05-03-2010 11:46 AM
Franksflying1
09-22-2009 11:27 AM
