brake lights
The 67 SS/RS is almost all back together, Starts, goes forward, backward, and stops . And the headlights work as intended. BUT there doesn't seem to be any brake lights. Turn signals work, also no interior lights. Usually if turn signals work brake lights work, but not in this case. Any ideas? fuses all look good.
Looks like going to take awhile to get all the sheet metal lined up as right , its a real mess. Didn't look to bad until put the hood on Floor was all messed up. When they put the T5 in it, they welded up the floor and cut a new hole and it is a lot farther back than what the Muncie with Hurst shifter wants. Sawzall a great tool for making new holes, but have to make a patch for the old one |
Check the brake light switch at the top of the pedal.
Did that previously and looks to be almost new. Just checked them again and now they working, little gremlins at work I guess. Still no interior lights, at all. even if try to turn on with light switch. So somewhere must be a loose wire or no connection. Dash and gauge lights work. They had the wrong sending unit for the console gauge and it now looks to be working a little better too. The Hurst shifter a real tight fit with the 4 speed plate installed on the console.
Originally Posted by gmshadow
(Post 728420)
Each ;ight circuit has its own power.
Check for brake lights "STOP' is fuse name. Tried emergency flashers? |
hello, new member I bought a 1980 Camaro brake lights work,but when I start the car the taillights are on without turning on headlights on.also the signals don't work and have replaced all bulbs.my question is why do taillights come on when I start car?
| All times are GMT -5. The time now is 03:52 AM. |
