Body Bushing Placement/Size??
I am restoring a 67 and I am the point of re-installing my subframe. I am having a problem trying to install the new rubber body bushings. The problem is, there are no instructions, and there are 3 different sizes. (2 small diameter, 2 big diameter short, and 2 big diameter tall- almost 3/8" difference)
I know the small diameter ones goes under the radiator support, but I am not sure which larger diameter bushing goes in the middle and which one goes in the back. I am assuming the taller ones go under the firewall, but I would like to make sure.
I figured someone here must have ran into this before?
Thanks
Thanks
Heres a diagram and heres where I found it. This link is for billet mounts but the sizes should be the same
67 - 81 Camaro/Firebird Billet Aluminum Body Mounts
chevcamaro
12-05-2011 12:06 PM
