Battery ground wire
Old Mar 3, 2023 | 06:53 PM
Sandys007's Avatar
Default Battery ground wire
I have a 67 and I don't have a spot left on water pump because of pulleys.can I run and bolt it to the block for a ground from the battery?
Old Mar 4, 2023 | 08:40 AM
Sure, Primary ground is the block since the starter uses the most power and it grounds to the block. Not grounding to the block or something bolted to the block would be an issue.
Old Mar 4, 2023 | 11:24 AM
Yup just be sure you get a good clean connection wherever you bolt it on.
charkbites
Jan 19, 2023 11:03 AM
BasicConcepts
Aug 12, 2011 11:54 PM
chucko
Dec 27, 2009 05:37 PM
finalstepmeek
82-92 V6 Tech
Nov 22, 2007 12:43 AM
Mister
Mar 24, 2006 02:42 PM
