Battery going dead
Old Oct 13, 2011 | 09:03 PM
Chevynutz's Avatar
Default Battery going dead
I have a 68 Camaro with a new battery and when i leave the ground cable hooked up for a day or so my batt. goes dead. Charging system is working as i checked it with my volt meter. Brake lights switch is working and dome light is is working. Any ideas on what may be drawing my amps and how to check it ? Could it be a shorted out cell in the batt. and get it load tested ?
Thanks
Old Oct 14, 2011 | 08:37 PM
overhaul2's Avatar
disconnect the neg cable,put a test light between the bat. and cable ,if the test light lights uo u have a drw. now pull one ufse at a time till test light goes out. when you locate the fuse ,see whats on that cicuit. replace fuse and disconnect each component 1 at a time till light goes out.that component is causing the draw.you may want too check alt. to see if it is causing a draw
Old Oct 15, 2011 | 12:48 AM
Chevynutz's Avatar
Thanks for the tips, i'll see what i can find.
Old Oct 26, 2011 | 08:04 PM
Chevynutz's Avatar
Default Bad batt.
Well it was a bad 7 mo. old batt. Never assume there good off the shelf i guess. Free replacement, yeehaw !!!
Old Nov 14, 2011 | 06:51 PM
Chevynutz's Avatar
Default Dead Battery
My new battery went dead and it was the damn glove box light not shutting off sometimes. Did not notice it until day light savings. LOL
Old Nov 14, 2011 | 09:25 PM
I was going to most , Glovebox light, trunk light or Lighter element. That would account for about 90% of the drain overnite issues I get.
ct1552
Jul 6, 2013 03:37 AM
Dana
Mar 26, 2013 04:10 PM
Itsalifestylee
Dec 16, 2010 09:33 AM
RiP
Sep 17, 2009 04:38 PM
Camaro_SS06
Mar 27, 2006 08:56 PM
