Almost finished restoring...need a little help
Old Jan 11, 2011 | 08:55 AM
67SuperSport's Avatar
Default Almost finished restoring...need a little help
Hi, I am in the process of finishing the resto in my 67 Camaro. Really all it needs now is paint (in a couple weeks), and a few tweaks under the hood and I'm good to go. Now after installing the rear end (12 bolt posi, 4.11 gears) I was thinking of putting ladder bars on. Would you guys recommend that or going with Cal-Trac? I would prefer ladder bars because of cost, but whatever works best, I can always save my pennies. The only problem I'm running into is that I have leaf springs and I thought ladder bars were made more for coil overs? This car is gonna see street but also alot of strip time as well. I also plan on tubbing out my rear end here soon. If anyone can help me out with this I would appreciate it. Thanks!
Oh by the way, here's some pics of the car.
468 BBC
And the MT slicks and fronts are going away, replacing those with MT Sportsman S/Rs aftr I get the rear shortened. Sorry I know the pics suck, the lighting is bad in my garage. And these were taken a while ago, so the car is more done now.
Old Jan 11, 2011 | 09:35 AM
shevrolay's Avatar
Hey...looks good, nice set up on the motor, is that a Zoops Alt. Bracket? You might want to play with that fuel pump to carb line, damn thing always runs so close to the lower radiator hose.
If it was simply a preference thing...I would go with the Cal-Tracs, I thought Edelbrock or somebody made a similar set-up if the Cal-Tracs are too much $$$. So was that originally a 4P car and somebody added the RS hideaways and SS Gas Cap?
It's hard to tell from the pics but are you still running the Mono-Leaf set-up and are you going to hook up some sub-frame connectors? Did you replace the sub-frame bushings with some new pg donuts? Are you still running with the 1/2 inch front sway?
Sorry if I am asking too many questions I just love build ups on 67's.
Old Jan 11, 2011 | 10:16 AM
Haha ask all the questions you need buddy.
That is indeed a Zoops Alt bracket. I love the way its so light and easy to put on. I am leaning towards Cal-Tracs more after looking into them. I found some for under $300 so it doesn't break the bank...
And yes it is a 4P car, and those aren't RS hideaways I just haven't installed the headlights yet. I have them but I think I'm gonna wait for paint first. And the SS gas cap is a replacement because when I got the car it was all rusted and just didn't look good.
I'm not running a Mono-Leaf, and no I did away with the front sway bar. I did add 2 subframe connectors a while back. And I have replaced all the subframe bushings.
Thanks for the help!
Old Jan 11, 2011 | 02:50 PM
Ok so I just learned that if I get my rear end tubbed they'll replace the leaf springs with coils, so most likely I'll go with a ladder bar setup.
Old Jan 12, 2011 | 12:14 PM
StoveBolts's Avatar
I was in the same situation for my 68 after having a custom set of springs made from Eaton Spring.
I called the guys at Competition Engineering to help me make up my mind between a 4 link or whatever was available and they put me into a set of Slide-a-links which they said would give me better 60 foot times than the 4link according to the HP, springs and Rear End I was running, so that's what I went with.
I've never seen the Cal-Tracks before, but they look just like the Slide a links with the exception that the C.E. SAL's are adjustable. I noticed the first time giving the car a bit of gas how the rear end of the car squatted and bit in. It was a great feeling where as the traction bars I orignially had didn't do much of anything lol.
Old Jan 12, 2011 | 12:15 PM
StoveBolts's Avatar
Just saw that. Well, that eliminates the Slide a Links then
imcdowel
May 24, 2012 03:42 PM
triplex08
May 31, 2008 10:00 AM
80z/28
Aug 5, 2007 06:26 PM
