Adding U17 console gauge cluster to my base 67
Old Sep 5, 2019 | 12:53 PM
CTJackster's Avatar
Default Adding U17 console gauge cluster to my base 67
If this has been asked before I apologize (searched beforehand) - I have a fairly base 67 with a base dash (Speedo + Fuel gauge & idiot lights) and D55 center console. I don't like driving a 60 year old car without knowing how hot it's running or what the charging situation is like, so I would like to add the U17 gauge cluster that mounts to the top of the center console (I think). I know I will need to buy the proper harness, U17 cluster and big tachometer; but I have some questions:
1. Can the big fuel / idiot lights gauge that occupies the right side of the main dash cluster next to the speedo be easily removed and swapped out for the big tach (once I have removed the main dash cluster and have it in front of me)?
2. I assume the oil pressure gauge is fed by a line (like my 65 Corvette) that is plumbed into the engine block - Do I need to drill a hole in the firewall for that or is one already present?
3. Back to the tach topic, this is a 210 hp PG (auto) car - which tach (redline) is correct? Could you even get U17 with an automatic?
4. How did the U17 gauge cluster mount to the console, originally?
Thanks guys.
CFI
Nov 28, 2011 11:27 PM
solei
Dec 5, 2008 08:34 PM
Stas
Feb 2, 2007 06:54 PM
johnjr
Jan 29, 2007 02:27 AM
