69 with no engine?
Old Feb 3, 2011 | 03:55 PM
Rose350's Avatar
believe me, brakes and suspension are definately on my list, its just not on the signature because its not that interesting, how does 6 piston willwood brakes on the front and 4 pistons on the back sound
Old Feb 4, 2011 | 09:45 AM
StoveBolts's Avatar
Sounds expensive, cause with all that, your going to want to replace your subframe, control arms and convert to rack and pinion steering too :-)
You should have a very nice car when your finished!
Old Feb 4, 2011 | 10:25 AM
Rose350's Avatar
i plan on going to a salvage yard and pick up a few turbochargers from imports, it won't be alot of boost, maybe 3 psi each, but twin turbocharging it to 6psi will yield in the 600hp range. the good thing about turbos is a boost controler, i can tell the wastegate to open at 0psi, meaning my engine is the only thing running, giving me about 400hp at the wheels
Old Feb 4, 2011 | 11:26 AM
Junk yard turbos on a 50K car, Really? Yea this is going to go well.
Old Feb 4, 2011 | 11:40 AM
But they do it in the movies.
Old Feb 4, 2011 | 01:23 PM
burnt68's Avatar
December 2010 ROTM
Just thought i would throw my 2 cents in.
in my opinion anything over 500 hp for a street car is pretty much a waste of money.
today you can build a sb with close to or at 500 hp for under 5g that will run on pump gas, use a healthy built auto or muncie with a 12 bolt rear and your good to go, no need for roll cages,3000 dollar brake set ups etc...
I would think you could find a real nice 69 body wise with a weak or blown engine
in the 10-15 g range.
you have the right idea buy the car for the condition of the body (no rust or bondo) the best money you can spend on a classic cause motors can be changed easily quarter panels cannot!!
Old Feb 4, 2011 | 01:27 PM
burnt68's Avatar
December 2010 ROTM
in your sig 620 hp when you race??
race where at a local drag strip? street racing?
Old Feb 4, 2011 | 01:57 PM
StoveBolts's Avatar
Sounds like your already trying to figure out how to be economical. I like that!
Sounds like you may have to get yourself a nice Tig welder too. You'll save a ton in the custom fabrication for your turbo's and besides, welding if fun, especially when your fabricating custome pieces for your ride.
Keep dreaming, it's good t dream. It's a lot of hard work when those dreams start to become reality (Unless you've got a lot of money to pay other people), but in the end, it's all yours, and it will be something to be proud of.
Old Feb 4, 2011 | 04:06 PM
dreamcar's Avatar
Where are you located at? I am thinking of selling my camaro. Would be around your price range.
Old Feb 5, 2011 | 11:44 AM
  #20
Rose350's Avatar
I'll answer your questions in order- Gorn-where did you get the idea that this is a 50k car?
Burnt 68, i cant remember if i said this already but i plan on getting a boost controller, so on the street it has a brake hp of about 400. Im family friends with the owner of a racetrack, so defiantly drag strip. Stovebolts-thanks man, its nice to hear support for my dreams. dreamcar-im in Oklahoma, but i'm willing to travel a bit to get a good car, what if you sold the engine and trans to collectors at a swap meet, they'd appreciate the parts more than i would
