69 ignition switch
I have a 1969 camaro non-tilt, manual transmissionsterring column that is currently out of the car and need to remove the ignition switch so I can put it in a rebuilt column ( I purchased from Ricks) Can anyone tell me how to remove the switch to put it in the new column. The switch and key work fine, should I use the originial or get a replacement.
thanks.
thanks.
