69 Flapper valve blows fuse
Old Jan 24, 2025 | 12:57 PM
CamaroX's Avatar
Default 69 Flapper valve blows fuse
Not very mechanically inclined here and could use some help. Recently (after 10 years), the hood flapper valve on my 69 Camaro quit working, blowing the 10 amp radio fuse. The radio will work with new fuse and energized. its only after start and initiating the flapper valve through acceleration does it blow. Does not look like it is shorting out at the flapper valve itself, could a bad relay cause this? or more likely and hard to get to, the switch at the accelerator arm? Any thought is appreciated.
/M3
May 31, 2023 07:22 PM
VietnamEOD
Aug 16, 2022 08:28 AM
Dan Blackmore
Aug 12, 2019 07:48 PM
ncbaby72
Jan 9, 2009 04:09 PM
gotalcoholmanup
Mar 1, 2008 07:00 PM
