69 Camaro..Just brought it in Yesterday...questions!!
Old Jan 9, 2011 | 07:50 PM
fpereira23's Avatar
Default 69 Camaro..Just brought it in Yesterday...questions!!
Hi Guys....FINALLY!!! my 69 is in my garage!!
Now I need your advise.
All the body parts are brand new from year one but it has no emblems and I already order the emblem kit. What would be the best way to open the holes needed for the emblems.....i just don't want to drill holes and chip the brand new paint.
I've seen on ebay some emblem templates, do I need one of those for the holes....any other way of doing it?
Also it has no hole for the antenna, so same as above...how do I open the hole for it?
Tks!!!
Old Jan 9, 2011 | 08:55 PM
The way to put a hole in the body panel is with a drill, you just need to be careful. As a safeguard, tape over the area, and well beyond, with a couple layers of wide painters tape.
If drilling bothers you, you could cut the mounting tabs off the emblems and mount them with double sided emblem tape.
Old Jan 10, 2011 | 09:47 PM
fpereira23's Avatar
Tks......are those templates any help for drilling the holes?
Old Jan 10, 2011 | 10:13 PM
The templates help you to get the holes, and the emblems in the right place. I don't know if the Camaro assembly manuals have this, they may not, but my Vette manuals give exact measurements to body reference points for all the emblem hole locations.
Old Jan 11, 2011 | 06:49 AM
fpereira23's Avatar
Tks for your help, I do have the assembly manual so I would go through incase they are there.
Old Jan 11, 2011 | 11:57 AM
orocker's Avatar
December 2011 ROTM
Santas Little Helper
My manual has detailed measurements on where mine go on the 69. You should be able to find info on yours in the manual.
Old Jan 13, 2011 | 05:12 PM
maggie67rs's Avatar
punch the emblems through card board or the like, outline the emblems, cut out your template, tape to panel where it looks right, mark the holes, drill, mount, done...next
Pablo63
May 3, 2010 06:42 PM
Alabama Camaro
May 17, 2009 08:34 PM
JRs72RS
Jan 3, 2007 01:57 PM
