69 camaro battery drain
Old Jun 2, 2012 | 08:55 PM
sgreg831's Avatar
Default 69 camaro battery drain
Something is draining the battery on my 69 camaro. Where is a good place to start looking? Thanks in advance
Old Jun 2, 2012 | 09:15 PM
Connect an ammeter between a battery terminal and the battery cable. Start pulling fuses one at a time till you find the one causing the draw, then see what that fuse is powering. Also check glove box lamp & make sure it goes out when closed.
Old Jun 2, 2012 | 09:25 PM
That's if he's small enough to fit inside the glove box.
A bad diode inside the alternator can cause a drain too. If the fuse hunt doesn't turn up anything, try disconnecting the alternator and see if the battery still drains as it's doing now.
BZpbp
Nov 7, 2012 09:22 AM
frmjersey
Feb 12, 2009 05:29 PM
jpucci
Aug 19, 2007 08:56 PM
jpucci
Jul 17, 2007 09:54 PM
Tom97V6
Apr 7, 2006 06:40 PM
